Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
A fixed number of lines is a quite rare case, to account for a variable number of lines to be read, a character sequence can be used to identify the end of the block of data.
e.g. 2 new lines MFI (<< end of DATA block("\!n\!n"))
Hello! Part of this request is available in JMP 18 (see screenshot) but it is only for Excel Files. I will leave this request open assuming this applies to the other formats as well.
hi @Sarah-Sylvestre , we need it for csv data. "dirty" measurement data with a footer.
Specifying the range is not applicable here, the length is not fixed.
For AI based analysis software such footers are no issue - but it's a severe issue for JMP. -> With JMP, an expert JSL scripter is needed to set up the flow. With AI everybody can "ask", no special knowledge is needed.
-> such a gab is dangerous for JMP.
