New to JMP? Let the Data Analysis Director guide you through selecting an analysis task, an analysis goal, and a data type. Available now in the JMP Marketplace!
A fixed number of lines is a quite rare case, to account for a variable number of lines to be read, a character sequence can be used to identify the end of the block of data.
e.g. 2 new lines MFI (<< end of DATA block("\!n\!n"))
Hello! Part of this request is available in JMP 18 (see screenshot) but it is only for Excel Files. I will leave this request open assuming this applies to the other formats as well.
hi @Sarah-Sylvestre , we need it for csv data. "dirty" measurement data with a footer.
Specifying the range is not applicable here, the length is not fixed.
For AI based analysis software such footers are no issue - but it's a severe issue for JMP. -> With JMP, an expert JSL scripter is needed to set up the flow. With AI everybody can "ask", no special knowledge is needed.
-> such a gab is dangerous for JMP.
