  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Workflow Builder + AddIns
☐ cool new feature
☑ could help many users!
☑ removes a „bug“
☐ nice to have
☐ nobody needs it
Workflow Builder just records part of the steps which a user performs in Jmp.
Especially commands from Add-ins are not recorded.
My wish: Enable Workflow Builder to record as many actions as possible.
Options:
  • Provide an easy way for Add-In Programmers to make the add-ins "suitable" to be recorded via Workflow Builder.
  • add a functionality to workflow builder to record the actions of existing add-ins (without adjustment within the Add-In)
  • add the steps as Main Menu("Add-Ins: command") - i.e. not fully automatic, but with some user interaction
  • add a dummy step to the workflow idicating that Workflow Builder was not able to grab an action
    (then the user can decide if this action was important and just in case try to re-do it using an official function)
https://community.jmp.com/t5/Discussions/Workflow-Builder-Add-Ins/m-p/573991/highlight/true#M78301
13 Comments
hogi
Level XIII
Thanks @Jeff_Perkinson for this beautiful workaround to get direct Jmp command calls into user-defined toolbars.
This makes them recordable via Advanced Log and Workflow Builder :)
in the jmpcust file:
<jm:action type="builtin">COLS:UTILITIES:TEXT TO COLUMNS</jm:action>
Another benefit compared to triggering the function via a JSL function:
If linked to the Jmp Command, the Shortcut icon gets "dynamic" - it's grayed out if it cannot be used:
hogi
Level XIII
great news:
https://community.jmp.com/t5/Discussions/Workflow-Builder-Add-Ins/m-p/637868/highlight/true#M83575
@jules wrote:
Hi @ih,
Unfortunately, at present (JMP 17.1) there is not a way to have Workflow Builder pick up jsl items from the enhanced log that originated from a script window or Add-In. We are working on a general fix in 18 so that this will be possible.
@jules
Sarah-Sylvestre
Level V
