  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Vertical version of Line Up Box
Exactly the same line up box we have now, except that we fix the number of rows and let the number of columns adjust based from data input.
It will be populated per column. I.e, Fill 1st column first from top to bottom, then create 2nd column and fill from top to bottom, repeat added all elements.
4 Comments
SamGardner
Level VII
@shaira thank you for the idea.  We will take this under consideration.
SamGardner
Level VII
@shaira We are looking into this and will get back to you soon.
SpannerHead
Level VI
Did this get developed?
Sarah-Sylvestre
Level V
