  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Validation column for Fit Parametric Survival
Hello,
This is a request to enable support for a Validation column for Fit Parametric Survival / Fit Model (Personality: Parametric Survival). Other Fit Model personalities (e.g., Standard Least Squares, Generalized Regression) have this option but Parametric Survival does not.
There is a workaround to support this through Generalized Regression using the Maximum Likelihood estimation method but supporting this in Parametric Survival would be more efficient.
Thanks and regards
Mehul Shroff
1 Comment
SarahGilyard
This request was captured and discussed at Discovery Summit in October 2024. There is also a tech support case for this request as well. Documenting this wishlist item as acknowledged.
