  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Update "Name Selection in Column" modal so there is no default value for "Unselected" field
I use the "Name Selection in Column..." feature all the time... I also delete the value of 0 in the "Unselected" field all the time so that any pre-existing values in my "Label" column will not be overwritten by that 0.
When I first started using this fantastic feature I frequently made the mistake of hitting the Enter/Return key as soon as I finished typing a string into the "Selected" field... and each time I would lose all the data I had previously written to the "Label" column. I don't make this mistake anymore, but I'm sure many new JMP users do.
I'd like to suggest that the default value for that "Unselected" field should be no value at all, consdering how relatively easy it would be to type "0" when that's actually (but rarely) the desired behavior, and how relatively dire the consequences can be when that is (almost always) not the desired behavior.
This is currently what users see when they open this modal:
3 Comments
Jeff_Perkinson
Community Manager
Good suggestion. We'll likely change the default for JMP 15.
Jeff_Perkinson
Community Manager
Status changed to: Delivered
In JMP 15 there are no default values for Selected and Unselected.
ttreynor
Level III
excellent! thank you!
