%3CLINGO-SUB%20id%3D%22lingo-sub-468642%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3EIntervalli%20di%20tolleranza%20e%20analisi%20della%20capacit%C3%A0%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-468642%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CP%3ECiao%20-%20Poich%C3%A9%20l'analisi%20della%20capacit%C3%A0%20%C3%A8%20un%20logico%20passo%20successivo%20nello%20sviluppo%20degli%20intervalli%20di%20tolleranza%20(TI)%2C%20sarebbe%20molto%20utile%20se%20sotto%20il%20triangolo%20rosso%20per%20il%20TI%20ci%20fosse%20un'opzione%20per%20spingere%20gli%20intervalli%20calcolati%20sulla%20piattaforma%20di%20capacit%C3%A0.%20Ci%C3%B2%20ridurrebbe%20significativamente%20la%20digitazione%20di%20questi%20valori%20e%20quindi%20ridurrebbe%20anche%20la%20possibilit%C3%A0%20di%20errore%20durante%20la%20digitazione.%20Ci%20consentirebbe%20anche%20di%20catturare%20automaticamente%20tutte%20quelle%20preziose%20cifre%20decimali%20nell'analisi%20della%20capacit%C3%A0.%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3EGrazie%2C%3C%2FP%3E%0A%3CP%3EKevin%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-468642%22%20slang%3D%22en-US%22%20mode%3D%22UPDATE%22%3E%3CLINGO-LABEL%3EAnalisi%20e%20modellazione%20dei%20dati%20di%20base%3C%2FLINGO-LABEL%3E%3CLINGO-LABEL%3EIngegneria%20della%20qualit%C3%A0%20e%20dei%20processi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E%3CLINGO-SUB%20id%3D%22lingo-sub-652185%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EOggetto%3A%20Intervalli%20di%20tolleranza%20e%20analisi%20delle%20capacit%C3%A0%20-%20Stato%20modificato%20in%3A%20S%C3%AC%2C%20restate%20sintonizzati!%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-652185%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3C%2FLINGO-BODY%3E
Tolerance intervals and Capability Analysis
Hello - Since Capability Analysis is a logical next step when developing Tolerance Intervals (TI) It would be super helpful is under the red triangle for the TI there is an option to push calculated interval(s) over to the capability platform. This would significantly reduce typing these values and hence also reduce the possibility of error while typing. Would also allow us to automatically capture all those precious decimal places in capability analysis.
Thanks,
Kevin
2 Comments
mia_stephens
Status changed to: Delivered
