To modify hover label editor so it is more user friendly
The options given by the hover label editor are very interesting. I think it's great that the information displayed can be customised. However, it would be useful for the hover label editor to be more intuitive. In particular I found difficult to navigate through the Gridtlet section. Maybe something that would allow to select the information so it can be added or removed rather than having to input manually?
3 Comments
nascif_jmp
Level VI
In JMP 16.0 we implemented a "visual" mode for the Hover Label Editor.
It was implemented along the lines described: if you right click on a hover label and select "Edit", a screenshot of it is captured and presented inside the Hover Label Editor.
Then you can click on it and the corresponding section of the editor (Textlet Gridlet or Graphlet) is displayed, and the appropriate content in the dialogue is populated.
For gridlets, the "Name" matcher is populated from the left-side of the hover label entry, so you just have to add it to the corresponding "Entries" panel and click Apply or OK.
Jeff_Perkinson
Community Manager
As noted above, JMP 16 will offer a more visual mode.
Jeff_Perkinson
Community Manager
Status changed to: Delivered
With the release of JMP 16 the hover label editor has a more visual mode.
