Text to Columns
Accessing the Text to Columns utility from the main Cols menu is cumbersome and inefficient.
Enable Text to Columns Utility to be accessed by riht-clicking the column and from the Column manager. Potentially also allow the utility to be simultaneously operated on multiple columns.
Why is this idea important?
Increased efficiency and ease of use.
3 Comments
hogi
Level XIII
another wish:
when I split a vector into multiple columns via
JMP generates formulas.
When I split a string into multiple columns, via
JMP just stores the values - without a formula : (
-> please add a formula! (either by default, as an option in the menu - or via the preferences)
hogi
Level XIII
If you use Text to Columns multiple times a day, you might add it to a Toolbar - or even assign a Keybord shortcut?
Toolbar with Text to Columns: QuickSelect Toolbar
mia_stephens
