Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Would be great to have an option to create a cloud of phrases, a "Phrase Cloud", in addition to the Word Cloud option for terms. Often the phrases (words together n in context) are more meaningful than the separate terms.
Interesting. You can do this now, with some effort, but you might distort the data. You can select the phrases in the right-hand column and right-click->Add-Phrase to move them to the left-hand column. The phrases will probably have much smaller counts than the single terms and not show up in the cloud at all. But, to see the effect, you can then make stop-words from the high-frequency terms (select, right-click->Stop word). In the process of making this example, I realized I was removing countries with one-word names, and probably other interesting terms. And accidentally removing Los Angeles, which I suppose I could have restored with the stop-word editor.
Stop word editor showing the stemmed phrase los angel*
The misleading word chart from random Wikipedia articles:
A big word cloud with phrases and terms
I wanted to know about "Wikipedia by expand", so I right-clicked in the word cloud->Show text to find articles like "article is a stub ... You can help Wikipedia by expanding it". Cool! But probably don't use stemming, it is hard to read.
Word cloud without stemming
