Support Snowflake TIMESTAMP_TZ data type
Unfortunately JMP's REST-based Snowflake data connector does not support the TIMESTAMP_TZ timezone-aware timestamp data type. JMP provides no value (null) for any TIMESTAMP_TZ value.
SELECT TIMESTAMP_NTZ_FROM_PARTS(2026, 11, 17, 0, 0, 0)
returns 11/17/2026 12:00:00 AM
SELECT TIMESTAMP_TZ_FROM_PARTS(2026, 11, 17, 0, 0, 0)
results in null
Return the TIMESTAMP_TZ values in local time instead of null.
Why is this idea important?
Best practice is to include timezone information for accurate analysis and reporting. Snowflake has supported this since its launch in 2015. There are no identified workarounds other than manually casting or converting to TIMESTAMP_NTZ in the SQL query, which means the Query Builder cannot be used.
1 Comment
DataExploration
Level II
Yes please! Would love to keep using jmp but all our data has moved to snowflake and this issue makes it close to unusable.
