A low priority request, but could help new JMP users. The term "Kruskal-Wallis" only shows up when you hover over the term "Wilcoxon" in the Fit Y by X for nonparametric, or after you run the analysis. After running, it shows "Wilcoxon/ Kruskal-Wallis Tests (Rank Sums)".
In preferences, when you search the term "Kruskal", it does highlight the Oneway platform and the Wilcoxon term.
Other software shows "ANOVA" and "Kruskal-Wallis" side by side. When teaching the workforce which test to use, in other software can point to the Kruskal-Wallis as a menu item, but in JMP, have to remind them it is the Wilcoxon menu item, and can see it will be the Kruskal-Wallis test for more than 2 items.
Could the actual term "Kruskal-Wallis" be shown in the menu item? Such as "Wilcoxon/Kruskal-Wallis" as the menu item under the nonparametric tests?
This is similar to having "Wilcoxon Each Pair" vs "Steel-Dwass All Pairs" clearly shown in the nonparametric multiple comparisons.
