Script to color cells in DoE setup
When creating a DoE setup, I often color the cells based on high/low/center level settings to highlight the system of the overall design. I have used the 'Value Color' column property to do so. @jthi automated the process of coloring the selected columns by the script given in this community post: https://community.jmp.com/t5/Discussions/Script-to-color-cells-in-a-DoE-setup/m-p/585788#M79141
Could a script like this be a default one with all DoE created in JMP? I believe that many DoE users would benefit from having this at hand when evaluating and comparing designs.
3 Comments
Hi @Steffen_Bugge, thank you for your suggestion! We have captured your request and will take it under consideration.
mia_stephens
