JMP Wish List
Row -> Color or Mark by Column / Row Legend
I'd like to request the following enhancements to the aforementioned row commands.
1. Allow the user to set the color and symbol based on different columns in the same dialog. Currently, it requires the process to be repeated, once for each.
2. Is it possible to add a third option, e.g., based on size / highlight, etc.?
3. For some analysis reports (e.g., Variability Gauge), the order in which the row legend is displayed is not in the order in which the selection was done. This differs from the beahavior in other analysis platforms. Can this be made consistent to other platforms?
Thanks and regards
Mehul Shroff
2 Comments
Hi @MShroff, thank you for your suggestion! We have captured your request and will take it under consideration.
MShroff
One more item to add to this request.
4. Can this functionality be enhanced to allow the selection of colors and symbols based on different columns in one dialog? Currently, each one requires the user to start over.
Regards
Mehul Shroff
