Rotate labels in Scatterplot Matrix
I wish I could rotate the Label Orientation to Perpendicular for ALL x-axes simultaneously in a Scatterplot Matrix. I have to rotate them one at a time, and the broadcast command using [Ctrl] doesn’t work for that.
2 Comments
hogi
Level XIII
This code will do the trick:
lbs= current report() << xPath("//ListBox");
xLabels= lbs[N items(lbs)]<< xPath("//TextEditBox ");
xLabels << Rotate Text( "Left" );
SarahGilyard
Status changed to: Needs Info
Thanks for posting dlifke. See the suggestion from user hogi. Let us know if this is sufficient for your needs.
