Robust Means and Standard Deviation functions in JSL and Formula Editor
Please consider adding the Robust Mean and Robust Standard Deviation functions already available in the Distribution platform to the Formula Editor and as JSL functions.  Thank you!
3 Comments
Sarah-Sylvestre
Level V
Hi @Kevin_Anderson, thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
Would be great!
Newly requested as an add-on to a larger list of robust Column Aggregation Functions:
Add normalization and robust statistical functions (and matrix functions)
hogi
Level XIII
Thanks for the many aggregation options which are available via Header Statistics:
If it's not possible to add the functionality via JSL - Is there a JSL function to get the values from the Header Statistics?
