  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Restore data-grid behavior: Pasting onto column names to rename them
What inspired this wish list request? In pre-JMP 18 versions, selecting one or more column names in the Columns pane and pasting lines from the clipboard would rename the selected columns based on the pasted text — typically separated by tabs or line breaks. In JMP 19, this no longer works. Pasting appears to be ignored, and does not affect the selected columns. Example use case: I have a text file with 10 new variable names and a JMP table with 10 unnamed columns. I used to be able to copy the names from the text file, select the 10 column headers in JMP's Columns pane, and paste — instantly renaming them. This was a powerful and elegant workflow for organizing data.
What is the improvement you would like to see? Please restore the ability to paste names directly onto selected column names to rename them. This used to be a very helpful feature and enabled fast bulk renaming, saving time and avoiding human error when copying names individually.
Why is this idea important? It allows quick, accurate batch renaming of columns without repetitive manual entry, saving time and reducing user error.
16 Comments
hogi
Level XIII
marked as removed in CTRL/Alt/Shift + click/select/double click/right click
@Sarah-Sylvestre could you please check if the absence of the functionality in JMP19 is considered a bug.
if it's no bug: how many kudos do we have to collect to get it implemented again? any chance that it will comeback in JMP19.0.1 ?
all the eastereggs in JMP are great. But if a function is not documented at all, there is a significant risk that it gets deleted accidentally:
Undocumented Secrets
duplicates of this wish:
Restore Column Name Update Via Paste
Please restore ability to copy-paste column names from one table to another
shampton82
Level VII
@BHarris
Oh man, if that went away that is horrible, I use that all the time!!  I kudo'd for support.
hogi
Level XIII
hogi
Level XIII
workaround in JMP19:
https://community.jmp.com/t5/Discussions/Undocumented-Secrets/m-p/907814/highlight/true#M106606
7 mouse clicks instead of (CTRL+V)
-> acceptable till JMP 19.1?
Sarah-Sylvestre
Level V
We're excited to share that this functionality will be available in JMP 19.1. It will work just like it did in JMP 18, with one small change: when you paste column names, a "Recode - Column Names" pop-up menu will appear. You can choose to interact with it or simply click Recode —either way, the core functionality remains the same.
I will also share some information from one of our developers on how you can currently accomplish this in JMP:
There are several ways to address this after your data is in JMP. However, it should be faster (and with better handling of column data and modeling types) to use import tools:
  • Use "Paste With Column Names" under the JMP Data Table "Edit" menu.
  • Excel-specific
    • Use the JMP Excel Add-in in the Excel ribbon to transfer your selection from Excel to JMP using the "Data Table" button.
    • Import your .xls or .xlsx file into JMP rather than using copy/paste.
BHarris
Level VII
@Sarah-Sylvestre :
Thanks for the update! I'm really glad to hear this functionality is returning — it was one of those small features that made a big difference in everyday workflows. That said, I'll admit there was something incredibly clean and intuitive about the previous behavior. When I select column names in the Columns pane and hit "Paste," I'm not really expecting — or hoping — for a dialog box to appear. It just used to do the right thing quietly and efficiently.
That said, I appreciate that the core functionality will still work, and I can definitely get used to the new flow. Being able to paste directly into the Recode Column Names dialog would also have potential. Looking forward to 19.1!
Last, re. currently functional workarounds, I've used Cols->Column Names->Move down, then paste over the names, and then ...->Move up to restore them as column names.  Requires tab- instead of newline-delimited values, but it's better than rebuilding the table.
robot
Level VI
I second the input from @BHarris about clean and intuitive behavior.
Why the change to "Recode - Column Names" pop-up menu?
hogi
Level XIII
perhaps my fault?
Recode and Recode Column Names: apply for specific rows/columns
or maybe
Recode Column Names- Only selected columns     @reese_sj
seems the developers liked this idea
-  and found the old way too secret?
We love secrets ; )
Plenary: John Sall on Secret Features of JMP®
Greenhorn
Level III
19.1 doesn't work like 18. It was such a useful feature. I'm very sad...
BHarris
Level VII
Is 19.1 released?  I don't see it as being available.
