  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Response Surface Design
When using the Response Surface Design, if we select for example 3 Factors and click on continue we get different choices of DOE.
Then, if we click on + in the Factors box to add 2 new factors, the box wit the Number of runs and the associated DOE is not updated. We need to click on Back and on continue to update the list of proposals.
Update the list of proposals when changing the number of factors or automatically remove the Box named Choose Design when changing the number of factors.
Why is this idea important?
It's confusing as in the custom design platform, the results on the number of runs is automatically updated when changing any factors.
2 Comments
mia_stephens
Hi @CarolineLG,
Which version of JMP are you using? In JMP 19, when you specify factors and click continue to view available designs, you can't change the factors unless you click the back button. This helps make sure the factor specification and available designs are aligned.
Mia
CarolineLG
Level III
Hello,
I am using JMP18.1.2.
Is it a bug that has been corrected with JMP19?
Best regards
