Regex: add options for all flags
☐ cool new feature
☐ could help many users!
☑ feels like a „bug“
☐ nice to have
☐ nobody needs it
The Regex search in Jmp is restricted because the user is not allowed to set all flags which are officially available for regex searches.
vs. what is possible in Jmp for Regex():
Please add options to enable/disable all flags.
Please start with standard behavior which matches other tools.
Why is this idea important?
At the moment, with singleline option enabled, the result of a Regex search in Jmp differs from what the user expects after debugging the Regex search outside of Jmp (unfortunately, there is no Test system in Jmp which can be used to debug Regex searches):
Regex: disable singleline option
So, it will be highly beneficial once
- Jmp behaves the same as the other tools.
- Jmp allows all options which the user finds in other tools.
2 Comments
hogi
Level XIII
Regex Match() is even more restricted than Regex():
There is no option to do a global search.
--> Related wish for Regex Match to get it to the level of Regex:
Add flag to Regex Match() to find all non-overlapping occurances of pattern
Sarah-Sylvestre
Level V
