  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Reference Line Column in Axis Settings
As I annotate processes, I like to have the option to use a column as my Reference Line Labels in the axis menu.
Furthermore..
At the moment it is not possible to have several times the same Label for reference lines like
„Temp.Issue“ and „Temp.Issue“ and so on for an reoccurring event .
Therefore a rename is necessary towards „Temp.Issue 1“ and „Temp.Issue 2“ ...
This topic should be solved as well.
It was addressed and solved in a jsl way but the proposal i think is more comfortable -
@martindemel
1 Comment
Jeff_Perkinson
Community Manager
@mlo1 wrote:
Furthermore..
Can you please separate this request into another Wish List entry? That way we can track the two items separately as they would be separate efforts.
Thanks!
