  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Profile -likelihood CIs for risk ratios
Proportional Hazards Fit provides profile likelihood based confidence intervals for the Parameter Estimates. Please provide this type of CIs also for the Risk Ratios; this is important because the risk ratios are the usual measure of effect size in survival analysis.
4 Comments
SamGardner
Level VII
@winfriedkoch0 thank you for this new feature idea.  We are evaluating this idea as a possible future improvement to JMP.
SamGardner
Level VII
SamGardner
Level VII
Status changed to: Needs Info
@winfriedkoch0 we have investigated this request, and I wanted to let you know that we do calculate and report Wald confidence intervals for risk ratios (hazard ratios) in Fit Proportional Hazards.  These confidence intervals use normal approximations for the confidence limits.  Does this meet your needs?
( output from example data VA Lung Cancer)
Risk Ratios
Unit Risk Ratios
Per unit change in regressor
Term
Risk Ratio
Lower 95%
Upper 95%
Reciprocal
Age
0.991487
0.9739
1.010136
1.0085861
Diag Time
0.999908
0.979971
1.016244
1.000092
KPS
0.967905
0.957488
0.978403
1.0331596
Range Risk Ratios
Per change in regressor over entire range
Term
Risk Ratio
Lower 95%
Upper 95%
Reciprocal
Age
0.669099
0.288517
1.606371
1.4945466
Diag Time
0.992119
0.175518
3.998028
1.0079435
KPS
0.05484
0.020935
0.143244
18.23482
Risk Ratios for Cell Type
Level1
/Level2
Risk Ratio
Prob>Chisq
Lower 95%
Upper 95%
Large
Adeno
0.4544481
0.0092*
0.2511038
0.8224612
Small
Adeno
0.7176217
0.2286
0.4181316
1.2316242
Squamous
Adeno
0.3047391
<.0001*
0.1690124
0.5494621
Small
Large
1.579106
0.0862
0.9370433
2.6611104
Squamous
Large
0.6705696
0.1574
0.3853373
1.166935
Adeno
Large
2.2004712
0.0092*
1.2158629
3.9824176
Squamous
Small
0.4246514
0.0019*
0.2476225
0.7282408
Adeno
Small
1.3934918
0.2286
0.811936
2.3915917
Large
Small
0.6332697
0.0862
0.375783
1.0671865
Adeno
Squamous
3.2814957
<.0001*
1.8199618
5.916725
Large
Squamous
1.4912695
0.1574
0.8569458
2.5951289
Small
Squamous
2.3548727
0.0019*
1.3731721
4.0384051
Risk Ratios for Treatment
Level1
/Level2
Risk Ratio
Prob>Chisq
Lower 95%
Upper 95%
Test
Standard
1.3363418
0.1617
0.8903074
2.0058347
Standard
Test
0.7483115
0.1617
0.4985456
1.1232076
Risk Ratios for Prior
Level1
/Level2
Risk Ratio
Prob>Chisq
Lower 95%
Upper 95%
Yes
No
1.0750063
0.7554
0.6820551
1.6943478
No
Yes
0.9302271
0.7554
0.5901976
1.4661572
SamGardner
Level VII
Status changed to: Delivered
Based on additional communication, the Wald confidence intervals are sufficient to meet this need.  Thank you for your suggestion and continued engagement with JMP!
