Print Preview and Print Margins
When printing a dashboard or series of charts, there's no easy way to print everything cleanly onto one sheet of paper for our reports. I use a wide screen monitor so I have to change the JMP window to what I can eyeball is the correct aspect ratio of the paper and then try to rearrange my dashboard to the correct sizes and ratios before pressing print preview to see if i was anywhere correct. Usually I'm incorrect the first couple times leading to lost time and wasted print area.
I would love similar to excel the ability to create an overlay that shows the print area for your selected print size. so I can arrange everything to fit within the page margins. The ability to unequally scale my graphs when fitting to one page.  Possibly a method to lock my window's aspect ratio to a "print format" so I can change everything in that window before sending the print option. So it doesn't need to be in a print preview window, the window is just already at proper print ratios.
And with all this, being able to scale, an option to have text displayed in graphs scale so it's always at a certain size. shrinking down screenshots to fit a print area crunches the readable data.
Why is this idea important?
We use a lot of paper printouts for data. Or after that data is sent, recipients want to be able to easily print it as well.
1 Comment
Sarah-Sylvestre
Level V
Thank you for submitting this request!
