Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Graph Builder Toolbar streamlines interactive graphing. Creates shortcuts on Report and GraphBuilder Helpers toolbars. Download and install the extension.
Not sure why it deleted my text, luckily had pasted it to the side!
What inspired this wish list request? Currently you can copy and paste local data filter settings between local data filters on different analysis windows. However, if you'd like the local data filter to be what you filter the whole data table with you have to recreate the filter.
What is the improvement you would like to see? I would like to see the ability copy a local data filter and paste it into the data table filter. The default can still be that only selected is chosen and a user can then select whether to turn on show and /or include.
Why is this idea important? This will reduce the redundancy of recreating a filter, which can be very burdensome for complex filters with lots of character
Also, sorry your text got deleted! I've seen this happen before and I might know what the problem is. The wishlist template has "hints" (italicized text), and if your cursor is not positioned properly within the template, your response might also become italicized. This means your response gets lost when you post. Hopefully this helps so you don't run into that issue again!
