Passing Bablok
Instead of having the method comparison addin, it would be nice to have passing bablock regression as an alternative to linear regression within Fit y by x.
Advantages:
No need to further keep the method comparision addin uptodate. Also it does not work well in the germen language environment.
Possibility to compare quickly different regression methods.
6 Comments
Dirk_Greis
Level I
Passing-Bablok is the preferred method for in vitro diagnostics comparisons when using patient samples (recommended by Clinical and Laboratory Standards Institute (CLSI) in EP09-A3: Measurement Procedure Comparison and Bias Estimation Using Patient Samples; Approved Guideline).
Are you aware you can do this today as an Add-In?
harald_ackerman
Level II
Yes, I am aware. But there are several issues with that tool.
You get errors in the journal when saving the analysis in the journal.
A native function in JMP allows to be highly flexible.
Thanks
Harald
Audrey_Shull
Status changed to: New
I can report that there has been work in this area for JMP 17. Passing Bablok analysis is now available in Fit Y by X, as an option for Bivariate regression analysis. JMP 17 will be available externally in fall of 2022.
harald_ackerman
Level II
wonderful :)
Thank you, appreciate this.
Status changed to: Delivered
