  • See how to create experiments to support product design and ID useful product features. Register for June 12 webinar, 2pm US Eastern Time.
Passing Bablok
Instead of having the method comparison addin, it would be nice to have passing bablock regression as an alternative to linear regression within Fit y by x.
Advantages:
No need to further keep the method comparision addin uptodate. Also it does not work well in the germen language environment.
Possibility to compare quickly different regression methods.
6 Comments
Dirk_Greis
Level I
Passing-Bablok is the preferred method for in vitro diagnostics comparisons when using patient samples (recommended by Clinical and Laboratory Standards Institute (CLSI) in EP09-A3: Measurement Procedure Comparison and Bias Estimation Using Patient Samples; Approved Guideline).
Are you aware you can do this today as an Add-In?
harald_ackerman
Level II
Yes, I am aware. But there are several issues with that tool.
You get errors in the journal when saving the analysis in the journal.
A native function in JMP allows to be highly flexible.
Thanks
Harald
Audrey_Shull
Status changed to: New
I can report that there has been work in this area for JMP 17. Passing Bablok analysis is now available in Fit Y by X, as an option for Bivariate regression analysis. JMP 17 will be available externally in fall of 2022.
harald_ackerman
Level II
wonderful :)
Thank you, appreciate this.
Status changed to: Delivered
