The need to compare the model built from a DOE ran in a simulation software with the model from the exact same DOE ran in an experiment in the lab.
Overlay in the profiler if two different models in the same row. For more detail please look at the post below
https://community.jmp.com/t5/Discussions/Overlay-profiler-from-two-different-models/m-p/708222#M8925...
Why is this idea important?
It helps to see the mismatch between the simulation and the experimental DOE results and helps calibrate the simulation software model better and design better DOEs in the next experiments.
