JMP Wish List
Nest Local Data Filter under same outline box as report
I frequently right click the gray triangle > Edit > Copy picture to export report images. When I use a local data filter, I need to use a screenshot to capture the LDF.
When adding a LDF, nest it under a new outline box with the original report.
Why is this idea important?
Easier to export graphics without screenshots and ensure that the filtering options are recorded as well.
2 Comments
I don't think the current behavior of local data filters should be changed (maybe it could be a preference which is by default off?). Selection tool jthi_3-1686024847161.png makes this already quite easy. With selection tool select both outline boxes
right click and select copy
andrewtkarl
Yes, that works, thank you.
