  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Nest Local Data Filter under same outline box as report
I frequently right click the gray triangle > Edit > Copy picture to export report images. When I use a local data filter, I need to use a screenshot to capture the LDF.
When adding a LDF, nest it under a new outline box with the original report.
Why is this idea important?
Easier to export graphics without screenshots and ensure that the filtering options are recorded as well.
2 Comments
jthi
I don't think the current behavior of local data filters should be changed (maybe it could be a preference which is by default off?). Selection tool jthi_3-1686024847161.png makes this already quite easy. With selection tool select both outline boxes
right click and select copy
andrewtkarl
Level IV
Yes, that works, thank you.
