  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Multiple Comparison ANOVA
このウィッシュリストのリクエストのきっかけは何ですか?
多重比較をよく「知らないものがJMPで分散分析をすると「各ペア、studentのt検定」を使ってしまう誤用?を何度か見たことがあります。(平均の検定の選択において)t検定という言葉は聞いたことがあるがその他は統計の授業では聞いたことのない検定なので、あえて使わない・・・
どのような改善をご希望ですか?
今後の更新において、分散分析の際には「各ペア、studentのt検定」を
デフォルトから外すか、隠れオプションとして頂けることを希望いたします。
このアイデアはなぜ重要ですか?
分散分析における結果の解釈の誤りを起こしにくくする。
1 Comment
SarahGilyard
Thank you for posting, BicycleRider. As you stated, the t-test is the "classic" statistical test for comparing means and is often misused in situations for multiple comparisons of more than 3 groups. We will discuss internally potential options to better illustrate that a multiple comparisons method using family-wise error rate correction should be employed for comparing more than 3 groups.
