  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Multi-File-Import: restrict number of lines to read
MFI is a versatile tool to load multiple files at once.
There are many settings to adjust the behavior like:  import as table/rows, adjust separators ...
For the header, there are options to specify the first header line and the number of header lines.
For the data, unfortunately, there is just an option to specify the first line with data - but no option to restrict the number of lines to read :(
MFI: load some rows
Please add an option to specify the number of lines to read.
Why is this idea important?
If a restricted number of rows has to be read [e.g. if the user wants to read (part of) a complicated header], the only way at the moment is to read the whole file and then delete the unwanted part.
The new option to restrict the number of lines to read will make MFI more versatile - and faster for cases where just a part of the file has to be read.
It can be extremely useful in combination with the option
<<Set Import Mode( "Row Per Line" )
6 Comments
Craige_Hales
Take a look at the random sample options from the other csv import so this can look similar.
I think there is a request to ignore comment lines identified by a prefix, as long as you are in that code.
hogi
Level XIII
ah, thanks, even more options that make sense.
a pity that the options are just available in the open csv dialog:
hogi
Level XIII
Another thing:
There are files with "header" lines below the data block (some infos about the measurement system). So, somehow a "footer".
At the moment, without the possibility to restrict the length of the read-in data block, such lines can ruin the data import.
With the new option to specify the number of lines to read , the issue can be solved.
but most likely, the data block doen't have a specific length.
So perhaps, in addition to
- End of Field characters
- End of Line characters
Jmp could ask for a
- end of DATA block character sequence
e.g.: data block ends if there are 2 consecutive newLines:
MFI (<< end of DATA block("\!n\!n"))
hogi
Level XIII
@Sarah-Sylvestre .
-> wish can be marked as Duplicate.
There is already a wish form 2019 - with status Acknowledged:
a way to specify when the data ends or the number of data rows to import when using multiple files i...
let's hope that it will get accepted soon ...
hogi
Level XIII
Sarah-Sylvestre
Level V
