%3CLINGO-SUB%20id%3D%22lingo-sub-347910%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3EDimensione%20minima%20della%20divisione%20sugli%20alberi%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-347910%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CP%3EMi%20piacerebbe%20avere%20la%20possibilit%C3%A0%20che%20la%20dimensione%20minima%20della%20divisione%20per%20i%20modelli%20di%20albero%20sia%20basata%20su%20una%25%20della%20dimensione%20del%20campione%20di%20addestramento%20rispetto%20a%20un%20numero%20intero.Quindi%2C%20ad%20esempio%2C%20potrei%20chiedere%20che%20la%20dimensione%20minima%20dello%20split%20sia%20il%2010%25%20della%20dimensione%20dei%20campioni%20di%20addestramento%2C%20arrotondata%20per%20eccesso.%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-LABS%20id%3D%22lingo-labs-347910%22%20slang%3D%22en-US%22%20mode%3D%22NONE%22%3E%3CLINGO-LABEL%3EStatistiche%20e%20analisi%3C%2FLINGO-LABEL%3E%3C%2FLINGO-LABS%3E
Minimum split size on trees
I'd like to have the ability for the minimum split size for tree models to be based upon a % of the training sample size vs a integer number.  So for example I could ask that the minimum split size would be 10% of the training samples size, rounded up.
