  • JMP Security Notice: CVE-2026-109618 and CVE-2026-109619
    JMP promptly initiated a review of its products, services, and relevant infrastructure for exposure to CVE-2026-109618 and CVE-2026-109619.
    Our assessment of JMP products has not identified exposure to these vulnerabilities. Where remediation was required within supporting environments, appropriate security updates and controls have been applied and validated.
    We have identified no evidence of successful exploitation or unauthorized access to JMP systems or customer information associated with these vulnerabilities.
    JMP continues to monitor the issue and relevant vendor guidance. No action is required by JMP customers at this time.
Make the quoted string in the :Name() function an evaluated element
I would like the quoted string in the :Name() function to be an element that JMP evaluates, rather than just being a quoted string.  I would like the below script to work
names default to here(1);
dt=current data table();
thename="NPN1";
bivariate(x(:Name(thename)),y(:Pnp1))
4 Comments
gzmorgan0
Super User (Alumni)
I agree this would make the syntax consistent.  Currently, I like to use, and train to use, the syntax, column(<dt,> "name") or column(thename), which I know Jim is aware of. Just adding a ditto to Jim's wish list item, and showing an alternative to those reading this on the blog.
mjoner
Level VI
I like this idea, too. Another potentially acceptable option might be As Name(thename)?
John_Sall
Name is always intended as parse-time. There are plenty of ways to make the reference indirect, e.g. :
Open("$Sample_Data/Big Class.jmp");
theX = "weight"; theY = "height";
Bivariate(Y(eval(theY)),X(eval(theX)));
Jeff_Perkinson
Community Manager
Status changed to: Not Planned For Now
