  • Register to see how to import and prepare Excel data on Jan. 30 from 2 to 3 p.m. ET.
Make the quoted string in the :Name() function an evaluated element
I would like the quoted string in the :Name() function to be an element that JMP evaluates, rather than just being a quoted string.  I would like the below script to work
names default to here(1);
dt=current data table();
thename="NPN1";
bivariate(x(:Name(thename)),y(:Pnp1))
4 Comments
gzmorgan0
Super User (Alumni)
I agree this would make the syntax consistent.  Currently, I like to use, and train to use, the syntax, column(<dt,> "name") or column(thename), which I know Jim is aware of. Just adding a ditto to Jim's wish list item, and showing an alternative to those reading this on the blog.
mjoner
Level VI
I like this idea, too. Another potentially acceptable option might be As Name(thename)?
John_Sall
Name is always intended as parse-time. There are plenty of ways to make the reference indirect, e.g. :
Open("$Sample_Data/Big Class.jmp");
theX = "weight"; theY = "height";
Bivariate(Y(eval(theY)),X(eval(theX)));
Jeff_Perkinson
Community Manager
Status changed to: Not Planned For Now
