Make JMP Graph Interface with BY visible at the top Graph setup screens
Some of the graphing options (i.e. BY) are not available at the initial GRAPH BUILDER screen.
Make this Graph Interface visible at the GRAPH BUILDER main screen.
JMP Tech Support identified that you can get to the interface that has the "BY" by going to REDO->Relaunch Analysis
Why is this idea important?
In it's current location, most end users are not even aware this interface exists or that it is possible to use BY without manually coding it in a script.
1 Comment
Hi @GraphOTE thank your for your request, we will investigate this internally.
