  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
Make Column Properties accessible from within Graph Builder and Distribution Platform
Usually I notice in Graph Builder or Distribution that certain Column Properties need to be set or adjusted: Value Ordering, Units, Limits, Value Colors, ...
It would save time and make working with JMP more dynamic if those Column Properties were accessible with a right-click on the respective variable within Graph Builder, may it be on the x-Axis, y-Axis or in the Columns box on the left.
Having to go through the data table, into Column Properties and then back into Graph Builder interrupts the analysis procedure more than is necessary.
The same goes for Recode.
3 Comments
Sarah-Sylvestre
Level V
Hi @gerd, thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
Value ordering got available via Edit mode in JMP16:Drag-and-drop Value Ordering in Graph Builder
same for Value Labels.
hogi
Level XIII
