  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Life Distribution plot points should default to Kaplan-Meier or Turnbull estimates with option to select midpoints
As a reliability engineer, I frequently use the Life Distribution platform for its distribution plotting and fitting capabilities.  These plots are important not only for internal topics but also for critical customer communications.  Unfortunately, the method of plotting data points in this platform changed in JMP 17 in a way that is less desirable.
These plots are often used to demonstrate the quality of fit of a distribution model to data.  Such demonstrations can be crucial in obtaining acceptance.  The Kaplan-Meier / Turnbull estimates used in JMP 16 were appropriate for this, as a good MLE distribution fit often came close to the estimates.  For example, see the Weibull MLE fits below (same data table, different versions).  Both MLE Weibull fits are identical, however JMP 17 points are significantly below the fit.  This change to the default behavior is troubling - now I must question which version of JMP was used when reviewing plots.
JMP 16 – “great fit!”
JMP 17 – “not such a great fit?”  (same fit!)
In JMP 17 the user can select Points (black, default) / Step Function (red) / Both / None.  Both selected below:
However there are a some issues with this:
  1. User has no customization options for the red markers (which are what should be default).  Need ability to adjust color, marker, size, etc. just like regular markers.
  2. Buggy behavior: selecting Step Function does not work when going from one of the other options.  It works when the platform is first launched if selected as platform default in preferences, however when toggling from Points back to Step Function it once again shows nothing.  Even if selected as default in preferences, once the “Nonparametric” distribution is deselected the red markers disappear and can only be recalled if “Both” selected.
The default point positions should be the “step function” points (Kaplan-Meier / Turnbull estimates) to be consistent with previous versions.  It would still be nice to be able to select midpoints, however each option should have full marker customizability.
Why is this idea important?
These plots are often used to demonstrate the quality of fit of a maximum likelihood distribution model to data.  Such demonstrations can be crucial in obtaining acceptance.  The previous default Kaplan-Meier / Turnbull estimates were appropriate for this, as a good MLE distribution fit often came close to the estimates.  Deviating from this now with JMP 17 causes confusion and is inconsistent with previous versions.
4 Comments
mia_stephens
TomH
Level III
This has been addressed and fixed in JMP 18.1.  Thank you.
Doraemon214
Level II
Hi TomH and Mia,
Can you help explain how to set the life distribution plot markers and the weibull fit to use Kaplan-Meier or Turnbull estimates?
I am using JMP 18.2 which does not use it as a default.
And I could not find where to change the default in the preference section.
Thank you.
TomH
Level III
I could be wrong, but I believe the Life Distribution tool only uses the Turnbull estimator, which, depending on your dataset, may be identical to the Kaplan-Meier estimator.  In JMP 18 you can toggle between estimators via the Nonparametric Estimate Plot Options menu shown below.  FYI, I will also add a comment to your other question related to this.
