Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Enhance LearnBot’s responses by leveraging content from the JMP Community, JMP YouTube channel, and the full JMP website knowledge base.
Improve LearnBot’s support for the JSL by incorporating information and examples from the official JSL books and documentation.
When LearnBot recommends external resources or websites, these links should open in a new browser tab or window instead of replacing the LearnBot session.
Benefits
Integrating this content into the underlying LLM knowledge base could significantly improve the quality, accuracy, and completeness of LearnBot’s answers. This would help provide more relevant guidance, richer examples, and better support for both JMP functionality and JSL programming.
@Bmllnn - Thanks for submitting the wish. The LearnBot is a JMP extension available in the JMP Marketplace and you can submit your questions and comments here.
Regarding your question about knowledge base and source material - stay tuned. We update this periodically but typically do not make an announcement. For example, the YouTube channel is a source and if you ask the LearnBot for video guides, it can recommend a video from the channel. If a video is recommended, you can watch it in the LearnBot window and navigate back to your chat with the navigation arrows at the top.
