Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
Fit model allows the user to set up and launch an analysis but not close the launch window. This is useful when iterating through many versions of a model. Add this check box (but leave it unchecked by default) to every platform.
We have many platforms that allows this in JMP, but we are not planning to add this as a general design feature. Also, in my most JMP platforms now, a red triangle option exists to "Relaunch Analysis", which will bring up the previous launch dialog with the settings that were specified for that platform.
