  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
KCV Models as Standard Option for Combined Mixture–Process DoEs
In formulation and similar fields, experiments often involve both mixture components and process factors. For standard numeric DOEs, JMP offers RSM models as a default, making DoE planning and model selection easy. However, for combined mixture/process designs, the equivalent—KCV models—are not included as a default option. Users must manually select and enter all relevant effects, which is time-consuming and error-prone.
Add “KCV Model” as a default model complexity option in JMP’s DOE planning and model selection, just like RSM for "standard" factors. This would let users select KCV directly, with JMP automatically generating the correct model terms—no manual effect selection needed. KCV models would then serve as the default for mixture/process combinations, just as RSM models do for numeric factors.
Why is this idea important?
Automating KCV model setup would save time, reduce errors, and make DOE planning much easier for users working with mixtures and process factors. It would provide a practical, balanced modeling option that’s especially valuable in formulation, but also useful in any area where mixture and process variables interact.
3 Comments
mia_stephens
Hi @ASchurr, thank you for submitting this request, and for sharing the pdf.
mia_stephens
Koo-Rijpkema
Level I
I support both request and suggested direction of solution!
