Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
This came up during the JSL Unsession at Discovery Summit Europe today. The goal is to make potential capability issues with scripts more visible. So providing a function which parses through the script and collects all the JSL commands used (in a version the script worked well), checks what command has changed since then to the most recent version, and throws out a list of these commands. That way the user can see immediately if there are potential risks when transferring a script to a newer version of JMP.
