  • Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
JMP interoperability with Jupyter notebooks via Python
The request is for interoperability between JMP's python interpreter and Jupyter notebooks.
I could install ipykernel and jupyter with jpip from a JMP Python script. I was able to create a kernel for the JMP's Python interpreter. I was able to connect to this kernel in Jupyter and import jmp and import jmputils inside of code cells in a Jupyter notebook, but I was unable to run the jpip command to install matplotlib inside of JMP's Python interpreter. Of course, I could run this jpip command from the Python script inside JMP.
Why is this idea important?
This would be very appealing to many Python users, many of whom like to use Jupyter notebooks.
In addition, it would appeal to Emacs users. Most Emacsens prefer to spend all day inside Emacs. Org-mode is a fancy markup language for Emacs that supports interactive literate programming. It is similar to R markdown notebook. Via the Emacs package org-babel, there is a Jupyter "language" that enables connecting to Jupyter via a specific kernel. This "language" makes any programming language supported in Jupyter via a kernel available in Emacs.
1 Comment
Thank you for sharing this idea!
