  • Sign-in to the JMP Community will be unavailable intermittently Dec. 6-7 due to a system update. Thank you for your understanding!
  • JMP 19 is here! Learn more about the new features.
JMP Live Append Report to Folder
My department recently purchased JMP Live and we were hoping to have the ability to add a report to an existing report folder.  Currently the "replace" button only allows for exchanging reports present in the folder and not simply adding them.  To append in a new report, the user must rerun all existing reports and then "replace" with all the previous reports as well as the additional report.
The solution should allow users run a new report and while publishing, select an existing folder or report to add the current new report to.
3 Comments
Hi @danielrbiber
Good news: this feature is coming in JMP 16 and JMP Live 16.  A few example screenshots:
Also in version 16 is support for this in JSL.
Jeff_Perkinson
Community Manager
As noted above, this is coming in JMP 16.
Jeff_Perkinson
Community Manager
Status changed to: Delivered
JMP 16 has been released. Learn more about it!
