The measurement stdev is used in other calculations (such as tolerance analysis, as a bound for equivalence testing, etc.) and it would be easier for new users to understand the values in the Gage R&R analysis if the stdev column is visible by default. Otherwise they have to either back-calculate from the 6*Stdev value, or turn on the column by right-clicking and choosing the Std Dev column (and then going to File/Preferences to save it as a default setting...this isn't saved under Red Triangle/Platform Preferences). The Stdev column is on by default in the EMP Gauge R&R Results table already (in JMP18).
In the AIAG Gauge R&R Results table, include the Std Dev column as a default output column.
Why is this idea important? The measurement stdev is used in other calculations (such as tolerance analysis, as a bound for equivalence testing, etc.) and it would be easier for new users to understand the values in the Gage R&R analysis if the stdev column is visible by default.
