  • See how to design an experiment, explore factor-response relationships, assess tradeoffs, and ID best settings. Register for Sep. 11 Mastering JMP.
In plot, add ruler % or ratio function for the measurement, leave the measurement result in plot, so the ruler notation can be included in plot. The ruler notation can be clear if it needs.
What inspired this wish list request? Please describe the current issue that needs improvement or the problem to be solved that is not easy or possible right now, with an example use case.
What is the improvement you would like to see? Please describe the idea for improving JMP. Please include mock-ups, wireframes, screenshots, scripts, other documents or examples from other software that help describe the change you would like to see.
Why is this idea important? Please describe the value to you and/or other users if the idea is implemented (for example, ease of use, must have,…).
2 Comments
hogi
Level XIII
A picture might help?
Sarah-Sylvestre
Level V
Thank you for your request! It will be reviewed, and we'll keep you informed of any updates.
