Improved and Better Integration with PowerPoint and/or Google Slides
Tedious and frequent manual procedures to restore the structure of complex JMP outputs in PowerPoint: Limited translatability of page structure (page break, columns) from JMP to PowerPoint (i.e., Export >> PowerPoint). Note: Export to PDF is not a solution due to the image format and low resolution (PNG).
Option to output JMP reports (Journals and custom Windows) to PowerPoint and/or Google Slides, including page format features.
Why is this idea important?
Huge time saver and a substantial opportunity to reduce errors associated with the manual manipulation of report elements.
2 Comments
Thank you for submitting this request!
