Improved JSL Stack Trace in Log on Error
The current JSL log that is displayed on an error is lacking. Currently, it displays the following:
  • What type of error was thrown
  • What line threw the error (but not what file the line is in)
  • The body of the JSL file that was run (the entire body, even if it is extremely long)
  • Sometimes, a highlight in the body of the JSL file that was run indicating the line that threw the error. This does not always work.
It would be more informative to get the following debug information:
  • A stack trace of the calling functions, with details on which line in each calling function threw the error.
There's really very little value in getting a printout of the JSL file with the highlight when you can read through the file yourself and look for the erroring line. It takes up space in the log and makes me scroll past it to see the actual error that was thrown.
6 Comments
vince_faller
Super User (Alumni)
Even if it weren't nested inside builtin functions, it would be nice if this worked for user defined functions with 1 layer of builtins.
Hi @DavidLeber, thank you for your suggestion! We have captured your request and will take it under consideration.
hogi
Level XIII
hm, not always the right one!!
I remember cases where the error pointed to a line where a variable was defined.
But the error was caused by a completely different line.
So, it seems there is some logic behind the tracing "where was the variable assigned, this must be the source of error". This kind of logic can be quite misleading ...
Error tracing: JMP tries to "help"
hogi
Level XIII
hm, not always ...
There are many cases where JMP doesn't report the line of code: Error message - which line?
This level of information was problematic when users wrote the code, but it's an even bigger issue now that AI is writing the code.
- There are more errors.
- The errors can be very unexpected.
and due to the current limitation of error reporting:
- they are hard to find when you don't know where to look for them.
hogi
Level XIII
related wish: Error Types
hogi
Level XIII
