I would like to perform multivariable relative risk regression using JMP
Nowadays, when the outcome is relatively frequent, multivariable regression with presentation of findings and confidence intervals using relative risk (risk ratios) is preferred. JMP does not seem to have this capability.
1 Comment
SarahGilyard
Thank you for posting this suggestion. We will discuss this with our development team.
Please note that you can get Odds Ratios for Binomial responses using Logistic regression in the Fit Model platform, but you are correct that the RR isn't explicitly given in the output. You can compute it manually if needed by choosing to Save Probability Formulas from the red triangle menu, then using the Summary platform to take the mean over the groups of interest.  This does require a few extra steps to get the RR as desired.
