Don’t miss your chance to experience Discovery Summit Europe at our best available rate! Early bird registration through 31 Oct.
Image to Table JMP extension imports single or batch images as data tables. Useful to extract curves from pictures or convert image data to curve data to use in analyses like Functional Data Explorer. Download and install the extension.
another suggestion which helps me currently is to use File > Save Session Script. If I save the session script each day before I shutdown my computer, and then I open and run that script each morning after I open fresh instance of JMP, then all of my analysis and my entire analytic workflow (everything in my home menu) is preserved, even the data tables that I did not explicitly save in memory (e.g. "Untitled 113").
