How do I recover most recent work on JMP files in cases of unavoidable computer/JMP shutdown?
Is it possible to enable file recovery of open JMP files (similar to Excel) in case of unavoidable computer/JMP shutdown?
2 Comments
Craige_Hales
Just posted an add-in that might help with JSL scripts. Not for JMP tables.  Windows only. FileSnapper  FileSnapper
another suggestion which helps me currently is to use File > Save Session Script.  If I save the session script each day before I shutdown my computer, and then I open and run that script each morning after I open fresh instance of JMP, then all of my analysis and my entire analytic workflow (everything in my home menu) is preserved, even the data tables that I did not explicitly save in memory (e.g. "Untitled 113").
