  • Due to the recently reported Microsoft outage, users may be temporarily unable to access My JMP or experience a delay receiving their verification codes. If you have previously installed JMP on your computer, this outage should not impact your ability to access the software. My JMP services will be restored as soon as Microsoft resolves this issue.
How do I perform multiple comparison tests (on the means) when you have unequal variances
Let's say you are running a One-way ANOVA with 5 groups.  You test for equal variance and conclude that the assumption of equal variance does not hold.  You then evaluate Welch's test.  The p-value from Welch's test indicates that the 5 group means are not equal.  Is there a simple way to run a multiple comparison test (to compare the 5 means or a Dunnett's like test to compare 4 of the means to a control group) when you have unequal variance?
Ideally, this would be an option found in the "red triangle" when using Fit Y by X (for the One-way ANOVA case).  Perhaps found in the Compare Means choices (see attached for a possible example).
Thanks
3 Comments
cwillden
Super User (Alumni)
Hi Rich,
Give this a try.  It at least covers the Turkey HSD situation.  I just updated the add-in a couple days ago.
https://community.jmp.com/t5/JMP-Add-Ins/Games-Howell-Test-Tukey-HSD-with-Welch-s-correction-for-Une...
richnewman
Level II
Perfect!  Thank you for your help.
rc_hertzy
Level III
A modified suggestion is, once the variances are found not to be equal, to allow modeling of the variance as function of the mean, then re-test homogeneity of the model-estimated variances. Then the means comparison is done as before but using the modeled variances.
